AWS is not accepting key
rapper101
New User
Hey guys,
I am trying to connect to my AWS EC2 instance and at the first step of setting my account I have an error that , "Can not connect to API. Check credentials" and when I click on it I see, "
Error: AWS was not able to validate the provided access credentials
In order to create virtual machine, you need to grant policy 'AmazonEC2FullAccess' to the user and have available limits of running instances."
To be clear the credentials are correct, I have tested and used them with other apps.
If anyone knows why this is happening I would appreciate your help.
@rapper101 please ensure that you you have provided the correct rights " AmazonEC2FullAccess " to the credentials you are using. If not, then error that comes back an you see is not generated by 3cx but from AWS.
In this case we work in transparent mode and we show when AWS provides back to your request.
Please check the following link and ensure that all steps are followed :
https://www.3cx.com/docs/cloud-pbx-amazon-aws/
Zexus
