AWS Marketplace image
arcatech
What is the preferred method installing 3CX on Amazon AWS servers. Any instructions I have found reference a "3CX Phone System" image which is no longer available as far as I can see on Amazon Marketplace.
I have also tried manual instructions but the 3cxpbx package referenced cann't be found any more either.
Not on Azure either.
The Azure and AWS marketplace installation are temporarily not available. Please stand by as we are currently working on this.
For the time being, you may use the 3CX Portal to install the 3CX system.
I would strongly recommend using the 3CX Hosted machines instead.
Ok, no problem.
Is there a timeline on the Azure/AWS images being available again? Also, as all the documentation is geared towards using one of the images, and installing from command line was removed a few years ago, is there support available for installing in a self-hosted cloud environment?
With all the events of the last few weeks, I need if the strong recommendation to use 3CX hosted machines is in any way related? Details not required, simply if the recommendation has become stronger in the last few weeks.
Unfortunately no ETA can be provided, but I stated we are working on this.
About the 3CX Hosted and 3CX Startup, we were and we still do recommend using these options.
I understand your reference to the recent incident, although this was specific to the 3CX Desktop App and specific versions of the software (provided publicly from our side) and not the 3CX System.
I would like to use the 3CX Portal to install 3CX to Azure (calls delay with Teams Intergration so I want to try different hosting), do you have a kb that I can follow?
I selected Self-hosted with your cloud provider, selected Yes to restore backup, but not sure what would happen after I upload the backup?
Our AWS marketplace image is now available again after being verified by Amazon.
What about the Azure Marketplace?
Reactions: Dunblue
Hi @LawrenceT,
Unfortunately there is no ETA for that, we’re awaiting an update from their end regarding this. We have taken all the required actions on our side. Hopefully it will be relisted in the coming days. We will of course keep you posted.
Reactions: LawrenceT
Unfortunately, the way we have setup backup, report, and CDR extraction we can't use hosted,
Hi @LawrenceT,
Hello
Any update on when the Azure Marketplace image will be available again ?
Thanks in advance !
Hello
Thanks in advance !
Hi there,
Not yet I am afraid. Hopefully it will be within the next 1-2 weeks. We're in touch with Microsoft's Marketplace team.
We'l update you once we have something.
Hi there,
Any movement on the Azure image yet?
Same question, please could we get an update? Is there someone in Microsoft we can start leaning on as Partners?
Appreciate an update here for Azure Marketplace image. I have a client that I was going to be provisioning tomorrow morning (Friday May 19, 2023).
Azure marketplace image will be back online tomorrow according to Microsoft...
AshleyStokes
