AWS restore without License & FQDN
AGITC
Intermediate Cert.
We have had an issue with the FQDN releasing due to the missing updates (V15) and have been unable to get it back, working through installing updates hasn't helped.
I have tried running through the pbxexpress restore method using a backup that includes the license details but it fails reporting the domain is exhausted.
Is there a way to do the restore to a new instance without the license? I am pretty much resigned to the loss of the FQDN now and just trying to avoid configuring a new system again if possible.
Thanks for any help.
Do you still have access to the old instance via IP? If so just take a backup without license/FQDN and then you can restore and pick a new FQDN (assuming you are seeing no FQDN bound to your key in the customer portal).
Thanks Cobaltit
I have access via IP and have grabbed a backup both with and without the license/FQDN.
Trying to restore with pbxexpress only allows with the license/FQDN which then errors about the domain being exhausted (key currently has no IP or FQDN bound to it in Customer Portal) and if I try to restore using the backup without the license/FQDN it then errors with wanting the license/FQDN included.
Or are you saying to run up a new instance, manually install 3CX and then restore the backup? Linux novice so will be an interesting experience.
I don't do much with PBXExpress so maybe someone else can chime in about that. But you should be able to install it on a local machine (Windows or Linux) and restore the backup, picking a new FQDN then. Then take a backup with FQDN/Key and restore that via PBXExpress. Make sure you shutdown your old instances.
hughesdouglas
