Azure VM Sizing
kite
In your example, the difference is 12GB :)
In all seriousness though, it's a VM. Spin it up, and if there's an issue, upgrade it. If it's not breaking as sweat, downgrade. That's the beauty of using VMs.
Yes, 12GB = 4X increase. That's a major cost difference in Azure.
I know I can play around and figure out what works, but I'm not thrilled about experimenting at my customer's expense. That's the whole purpose of System Requirements.
Reactions: Oceanic504
Silent_Guru
