Solved Backup SFTP - Sub folder
David Bertrand
Following the information about Gdrive for backups I am working on another solution.
With my PBXs at OVH, I looked at the "cloud archive conteiner" that allow SFTP access. The problem is that SFTP access gives access to the root folder of the server in which 3cx does not have authorization to write.
It would be necessary for 3cx to have a subdirectory option to be able to write in the right directory
Is it possible to set this up somewhere?
This doesn't work .... sftp://gateways.storage.gra.cloud.ovh.net:/BackupsSFTP
Regards
I think you left a semicolon in there after the TLD
Also you should be able to create an account for SFTP access, and during the configuration of the account you can assign it a home folder that has has the necessary rights (depending on your service provider)
You might have to try it as: sftp://gateways.storage.gra.cloud.ovh.net/home/username/BackupsFolder
Hello and thank you for your feedback.
The host is : sftp://gateways.storage.gra.cloud.ovh.net
:/BackupsSFTP was to test the access to the subfolder directly
I'll look for OVH side but I'm not sure we can create a user for a specific folder.
Regards.
You might have to try it as: sftp://gateways.storage.gra.cloud.ovh.net/home/username/MyBackupsFolder
Be careful of the extra semicolon though
No, it unfortunately doesn't work, unknown host. I think it is necessary either that OVH allows the creation of users for a specific sub-folder, or to have the possibility in 3CX to choose the sub-folder.
You should look up their documentation. Experiment using filezilla client to connect to it and observe the path that appears on top for the remote site window
It's workin, thank-you very much !
Fillezilla give-me : /containers/BackupsSFTP
I have put as host : sftp://gateways.storage.gra.cloud.ovh.net/containers/BackupsSFTP
So for those who are looking for a backup solution and who are at OVH here is one;)
0,002 € HT/month/Go
Best regards,
David.
Glad to help David, thanks for confirming the solution :)
Kayla Norris
