Bandwidth.com Caller ID Issue
Kanwar
Hi Folks
I'm trying to set up Bandwidth with 3cx and ran into a Caller ID issue. I've used the template provided by 3cx and getting "Unknow " as caller ID. Is there any particular setting I should look into to fix the issue?
Best Regards
Did you check the activity logs to confirm Bandwidth is sending you caller-id? 3CX templates just 'work' so I'm assuming that's where the problem is
Reactions: YiannisH_3CX
postmaster@studiolegaleda
