I'm finally setting up my grandstream.
I have an issue, hopefully you guys can help me without opening a new thread. I couldn't find any thread matching my strings.
I can receive calls just fine but when I dial out :
-It rings fine ( at least is the "two short ring, pause, two short rings.." )
-after a few rings the soft phone says "connected" but it actually my cell phone, which is the # I called, never rang or shows any missed calls.
-when i make the call, the management console > Extension status of extension 101 changes to "Dialing", then "connected"
-the debug just says "video call not allowed". No errors
Could it be that comcast is faking the call or blocking it?
Suggestions?
EDIT:
I found more logs about calls. Please note i put xxxxxx for privacy.
I noticed that, e.g. at line 5 the first 3 digits have changed from 786 to 86. Is it ok?
23:01:56.905 [CM503008]: Call(34): Call is terminated
23:01:45.765 [CM503007]: Call(34): Device joined: sip:
[email protected]:5060;transport=udp
23:01:45.761 [CM503007]: Call(34): Device joined: sip:
[email protected]:50480;rinstance=e1430279e7cbd69a
23:01:45.743 [CM505002]: Gateway:[Grandstream_GXW4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 2.0, Ch:8) 1.3.4.10] PBX contact: [sip:
[email protected]:5060]
23:01:45.742 [CM503002]: Call(34): Alerting sip:
23:01:41.745 Currently active calls - 1: [34]
23:01:27.040 [CM503025]: Call(34): Calling PSTNline:86xxxxxxx@(Ln.10000@Grandstream_GXW4104)@[Dev:sip:
[email protected]:5060;transport=udp]
23:01:27.010 [CM503004]: Call(34): Route 1: PSTNline:86xxxxxxx@(Ln.10000@Grandstream_GXW4104)@[Dev:sip:
[email protected]:5060;transport=udp,Dev:sip:
[email protected]:5062;transport=udp,Dev:sip:
[email protected]:5064;transport=udp,Dev:sip:
[email protected]:5066;transport=udp]
23:01:27.005 [CM503010]: Making route(s) to <sip:
[email protected]:5060>
23:01:27.002 [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:
23:01:26.995 [CM503001]: Call(34): Incoming call from Ext.101 to <sip:
