Batch/Bulk importing extension (Accept multiple calls)
the_jackal_br2001
Forum User
Hi Guys,
I am using batch/bulk to import extensions in 3CX pbx, and there I configure everything I need, except an item called in the forwarding rules (Accept multiple calls) field. Does anyone know how I automate this?
I know use after import the extensions, select all extension and click in Edit Button and check mark the (Accept multiple calls) to save for all extensions, but if I can configure in the Bulk would be better. I do know if you guys have the same problem.
Hi there!
The forwarding rules is something that cannot be imported. I think your best bet would be what you already said, after you import everything, just select all the extensions and mass edit them.
Reactions: the_jackal_br2001
sls1
