BeroNet config for inbound calls
PaulEmous
On Prem v18 Linux, all updated and working
I have a beronet GMS Gateway that is doing my head in. It's configured using the wizard. It can make calls (outbound rule set, 345 -> number and works.) The GMS number is displayed. However if I try to call the number back, it goes straight to the carrier voicemail (not 3cx extension VM). The Sim is registered in the system and in the Call Plan log I can even see that the number is dialed. attached the log of the dail plan. I think the indicator here is that it shows no destination?
This used to be a lot easier.
Just to recap: with the standard wizard it used to work, outgoing calls work but incoming calls do straight to voicemail.
Hi Paul, I suggest you to enter in contact with Beronet so they can check and can assist you with the device settings.
Have a great weekend!
Bluebox Global
