Best way to Implement 3CX for a client with 2 independent Branches
vincent Kavila
Hello community
I have a client who wants to implement 3CX on their 2 branches which are independent.
What is the best way to go about it?
2 instances with bridging.
Cloud based 3CX, with each location having sbc server to manage the handsets
Probably need more info on setup - how many handsets , 3cx apps at each site, etc
In total are 25 handsets on all sites and over 30 softphones. Also, there will be a Yeastar TG1600 gateway, will it work with the cloud PBX?
One internal 3CX server, connected to the Yeastar TG1600 - not 3cx supported so you will have to manually configure it , or see if Yeastar have some configuration guides.
At the other site SBC server, handsets will use sbc server.
Softphones connect directly with the 3CX server using 3cx tunnel
Softphones connect directly with the 3CX server.
Okay, I think this makes sense to me. For the TG1600 I will manage, I have done it before.
Will a cloud PBX work as well?
StevenWillems
