beta version on LG phone does not load presence
Shawn
version 15.5.344.492 on LG Stylo2 android 7.0 kernel 3.10.49 build NRD90U Software version LS775ZVB
I loaded .492 and everything works except presence. it shows "loading" with the circle progress indicator spinning. reboot and reinstalls did nothing
any ideas?
i have other android clients on the same lan that work fine. actually this is the first that i've seen this issue. 5001 is open and reachable but i don't know of a way to verify this on the mobile phone or client itself. my samsung next to his LG on the same network and mine works but his does not.
Shawn, in the Management Console, check if extension is allowed to work outside of LAN.
the extension was not allowed to work outside the lan but i unchecked the "Disallow use of extension outside the LAN" option and it's still acting the same way. still says loading with progress indicator circling. i have about about 10 mobile phones of different varieties (ios and android) on the same wifi network and have not experienced this with any of them. i do believe this is the first LG phone that i've put on the network
also, i thought the "Disallow use of extension outside the LAN" only applied to desk phones and not mobile clients. can you please clarify this
I see that parameter's description is "Disallow use of extension", not "Disallow use of desk phones" - to me it looks a pretty clear and accurate description.
you're right, pretty self explanatory. either case, i'm still experiencing the same issue with this one particular phone.
any other ideas?
any ideas?
Same issue on Note 3 (Android 4.4)
Works fine on other Samsung n Pixel
2 phones with the same version android client, on the same wireless network with the same config file. one connects and functions fine while the other shows disconnected, waiting for network. it's on hook but status is not green. if i call the extension, both phones ring. presence does not load.
see attached pictures of the phones side by side.
any ideas why this would happen?
Shawn this appears to be the same problem I am having except I have a number of different types of cell phones that are not working. I m curious if yours works if you turn on WIFI. Mine work fine on any WIFI just not on a Cell carriers network. If you notice the one phone says waiting for network thus no presence. My original post is below.
"Hi Im hoping someone out there can help me out. I just updated our in house system to the the newest beta version (15.5.15060) now our android app only works on WIFI. If not on WIFI it just says waiting for network. All thoughts are welcome"
Sorry just noticed you said, and pictures indicates wifi is on. I was just hoping that I had found a common thread with my problem
Anyone from 3CX have any insight on this?
Curtis, I was going to reply but you beat me to it. Yes, they are both on wifi and one doesn't even have sim in it.
screen shots of the LG and Huawei phones in question here
If on the same local WiFi you have two or more (almost) identical configured 3CX clients, but some shows "On Hook" and have presence, while others shows "On Hook" but have no presence (and showing "Waiting for network") a good idea is to check the Management Console's blacklist - there is a good chance the phone not working is having its IP blacklisted.
Both phone has 100% same configuration
I sent 2 extension configuration to 2 phone
and registered 2 extensions one at a time on Note 3 (Android 4.4), NO presence information for both extensions
Where Pixel (Android 8.1) Works fine with both extesions
Pixel and Note 3 are connected to same WiFi, Same subnet
Then I uninstalled 15.5.344.492 and installed 3CX App 15.5.342.392 back on on Note 3, works fine
It is very clear App version 15.5.344.492 does not go well with Android 4.4 in my case
mobilowa, how did you manage to install different versions? is one available as general availability on play store and the other in beta?
Mahlon
