Billing Codes and Reports
Steve Medley
One of my clients relies very much on Billing Codes when making calls. We've been running into issue after issue on these so far and doing what I can to solve them. Wondering if anyone knows how to fix this:
  1. Enforce Billing Codes: I'm currently under the impression this is impossible without 3rd party software which is looking to be $1k+ per year.
  2. Billing Code Reporting: I can't seem to generate a report that covers multiple billing codes, I tried entering it as "1234,5678" as well as "1234 5678" but it doesn't work, this means I have to make a separate report for each and every billing code. Is there a way to have multiple billing codes in one report?
  3. The Important One: Since we can't enforce billing codes and since the 3CX system removes billing codes from reports (Shows 800-555-1212 instead of 800-555-1212**1234) there really really really needs to be a way to generate a report of numbers dialed with no billing code. I can't send them a report of all calls, then 27 separate reports for all of the billing codes in use and then ask them to manually de-duplicate them, to figure out who forgot to enter a billing code when they dialed out. If this is actually not possible then is there a way to customize the PDF columns so that it includes the billing code?
Bump, anyone know of a workaround on this?
I assume you are talking about our 3CX Advanced Billing Codes add-on for 3CX. We can indeed do all the things you have mentioned, and I should point out that you get all 20+ add-ons for that price which includes many tools for call centers including dialers, recording management, APIs for integrations, data exports for custom reports and much more. I encourage you to look at the entire suite of tools get so you have a complete picture of the value we bring to 3CX. We do a whole lot more than just billing codes.
gmacinit
