Solved BLF Indicator to show when an extension is in use
compumaxfl
Hi.. I am wondering if there is a way to have a desk phone indicate if another extension is in use? (red = in use, green = available). I know this is available in the Windows Client and Web Client, but not sure about desk phones. Thanks for your help! (Fanvil X5S)
We do support this, just edit your extension and visit the BLF tab.
Add some entries with the "BLF" type and select which extensions you wish to monitor.
Then simply reprovision your phone, and you should see the BLFs appear.
Thanks so much.. I was sure this was available, but never used this feature. - Bill
Reactions: JohnS_3CX
Glad to help!
EMMEPICASA
