BLF on T46 from bridged 3CX possible?
Remip67
Forum User
2 3CX instances are connected via a bridge.
Remote status/presence info is showing on both sides when I use the web-interface. Some users are using yealink T46S phones with an attached EXP40 module. I was trying to add remote BLF buttons in the configuration but the remote extensions don't show up in the interface. So I gues remote BLF buttons are not supported yet. Is this correct? If so, is there a work-around maybe to get BLF buttons from the remote system working?
Both systems are on V18 update 1 and have a professional licence.
Thanks in advance!
Remi
Hi Remi,
Remote BLFs are not something 3CX offers for deskphones. Currently there is no workaround. BLFs are something different from Presence so there is no method to add them for a remote PBX.
Your options are to either add custom speed dials (which will not monitor the call state) or use 3CX clients in conjunction with deskphones.
SupportRock
