BLF to prepend number
DDITD
Gold Partner
Hello all,
Is it possible to setup a BLF which will place a number sequence but not send immediately. I am attempting to setup BLF's which a customer can use as an outbound line in the traditional sense so they can use differnet outbound caller ID's.
In essence, select a BLF which will prepend 77 but not immediately send. Then the user dials the required number before sending. The Outbound Rule will remove the 77 before sending
Thanks,
Hello @DDITD
Please note that this functionality is not available on the 3CX PBX.
Reactions: DDITD
Hello @DDITD
Hi Dimitris,
Thank you for the reply.
So would it be fair to say my options are to instruct the user to manually prepend the prefix or use seperate extentions?
Hi @DDITD
That is correct, the best option is for the user to manually prepend the prefix.
Reactions: DDITD
You could use our "3CX Caller ID" tool. This tool allows the user to select from a list of pre-defined outbound caller ID numbers prior to initiating the phone call.
youwillbrun
