Solved Block Direct Dialing of Extensions
M.Knapp
We are currently hosted in the 3CX cloud - We are looking to block the direct dialing of extensions when at the digital receptionists menu\IVR. I see people are doing this with the custom parameters tab however we do not have the feature. Has anyone found a way to accomplish this? Thank you
@M.Knapp since you are hosted with 3CX, parameters option is not available in order to ensure the smooth operation of your system without any customizations.
Thanks - Do you know of another solution for this?
Use a DTMF IVR and configure all possible direct dials and options.
Reactions: YiannisH_3CX
mazet
