- Joined
- Jun 7, 2021
- Messages
- 20
- Reaction score
- 3
i have installed and provisioned some 3cx apps (Android and iOS) and even if i enable the "block remote tunnel connections" and the "Use 3CX Tunnel for remote connections" options i continue to recieve calls when not connected to the local LAN.
I have 2 self hosted 3CX instances, 1 on V16 and 1 on V18, and both have the same problem.
I have tried multiple combination of options but calls continue to arrive. On answering there is no communication because our firewall is not configured for external 3cx connections.
Does anyone else have this problem?
Thank you!
Thank you!
