Blocking Faxes
jmalin
Forum User
We're getting a lot of spam faxes to our office. Is there a way in 3cx to block them?
Are you talking actual faxes to your fax number/extension or just fax calls/tones on your voice line? Either way, the fact that it is a fax doesn't change anything. You block them the same way you block spam/bogus voice calls. Blacklist the number, talk to your provider to see if they have any spam/junk call mechanism (we offer Nomorobo for example) or wait until STIR/SHAKEN is implemented which will reduce spoofed calls.
Thank you, and thank you for all of your help. I appreciate it.
Is there a way to set up a block without the number? We're also getting a lot of spam faxes. I usually just add the numbers to the block list, but sometimes they come in without a fax number attached. Is there a way to block any faxes/calls that come in without a caller id number?
You receive strictly nothing sended on your sip trunk to identify this kind of calls?
my sip provider send me 0Anonymous as caller ID for calls without numbers, so i create a CID rule to reject this like that
11287
11286
This is what I receive:
Fax has been received from anonymous
Accepted: 2019-Jul-08 06:35:16
Callee: 888
Received: 2019-Jul-08 06:35:42
Caller: anonymous
Fax ID:
Pages: 1
perhaps this is your caller id
Caller: anonymous
try to create CID rule and see if it reach his goal or not, perhaps you can ask your sip provider to send you signifiant ID you can filter when on destination to your fax number and send with no caller Id.
Have also filters i can activate directly from my sip account manager on provider side so before it comes to my PBX
this is like it is , added nothing just received from my sip provider
I'll add that rule, and see if it helps. Thank you so much for your input.
fcentral
