Bricked Yealink T23G
ChrisKoll
SOHO User
I have a Yealink T23G Current Firmware 44.83.0.55, While in the management console I noticed Not Supported,
when attempting to update firmware all attempts failed including using Yealink recovery files, closer inspection Firmware 44.83.0.55 is a 3cx Firmware patch. Any ideas? or Just junk the phone.
Did you read STEP 1?
Note: If you are currently on a firmware version lower than x.84.0.35, and your model accepts a higher version, you need to manually upgrade to version x.84.0.35 prior to upgrading to a higher version
That the entire point, the phone will not use any firmware upgrade, including Yealink recovery files Thus Bricked Phone, the last update it did take is 44.83.0.55, I have tried T23-44.84.0.125.rom / from yealink and T23-44.84.0.95.rom / from 3cx
I think we are past that, I am at step 55
Again, step 1:
Reactions: sbrammer
I am not sure you get it, the manual update failed LOOK UP at the image I posted, do you see any other options that I missed?
It's hyperlinked right there in step one :
That was the first on I used, So far none of the have worked, I even tried to use the recovery files and my TFTP Server to reset the phone, but thanks anyway
Reactions: complex1
Yes that is true, I did not mention it, however I have been working on this for about 3 days, I simply forgot to include it in my post. Regardless the recovery files should have worked. My guess is I need a new phone, no worries. Just came here to see if someone else has had the same problems.
Gotcha. That's why we kept saying step 1 because you hadn't mentioned it and it's quite often missed the first time around (and sometimes the second). I don't know what exactly Yealink broke when they messed up that firmware but I agree that a straight recovery should work as well. Probably not worth wasting anymore time on it.
Reactions: ChrisKoll
Junk The Phone, too cheap to keep
tohoken1
