Bridge between 15.5 and 16. Will it work
[email protected]
Forum User
We need to update multiple systems from 15.5 to 16. We would like to do them one at a time. Will the bridge fail until both Master and Slaves are updated to V16?
Thanks.
Must have a Pro or Ent license in v16 to use the bridge, otherwise it should work fine.
All instances have PRO licence. Thanks.
I don't see any reason that a bridge trunk, for calls, would not work between versions. If the versions were quite a bit different, then there might be issues, if you were to use Presence.
It works, tested it.
Wecare_ITA
