Bridge Question - Routing Calls
Chris Wheeler
Gold Partner
If I have two systems connected via a bridge, can one of the systems have the telco trunk connectivity and route calls to the connected system based on the inbound call rules (DIDs).
Essentially share a PRI/T1/E1 between the two systems.
DID rules are meant to route a call to a local extension, you are attempting to turn that local extension into a number that can be utilized by the outbound rules. I have not seen that done as , in many cases, it requires a routing prefix.. What you may have to do is create dummy extensions on the PBX with the outbound trunks. Forward calls across the bridge from each of the extensions.
Texas Clay -
