Bridge WAN/LAN in ATA - Add to provisioning template. - Feature Request
AlltechIT
Platinum Partner
Yes, customers still use fax.... we have had very good success with Grandstream ATAs using T.38. It would be great to see the option for bridging the WAN/LAN port built into the template. We ship these to places where they are connected in line with the data cable at multifunction copiers. When they are using NAT by default, we can lose communication with the copier. We manually modify the XML now to bridge the device on initial shipping or install. If someone is troubleshooting or we need to replace one, they may just grab the config from the PBX. This cuts off communication to the ATA LAN side and the devices behind the NAT. I would think this an easy add to hardware where the feature is available. May a box for Bridge WAN/LAN to check that changes the 0 to 1
Thanks for the consideration!
NAT/DHCP Server Information & Configuration
Device Mode. 0 -NAT Router, 1 - Bridge
Number: 0,1
Mandatory Reboot required
P231 1 P231
Upvote 0
Graham Robertson
