Solved Bridged ext showing as local ext
Alphabetic
3CX MVP
Hi all
PBX A and PBX B have the same extensions.
When Ext 1 calls from PBX B to PBX A it shows that the caller is ext 1 from PBX A.
Is there a way around this?
Make different extensions for PBX A and PBX B
I'm guessing ext 1 on both PBXs is the same extension number yes?
If yes, go into PBX's A Bridge settings and add the bridge prefix here:
Reactions: Alphabetic
ah perfect thank you.
Reactions: ChrisC_3CX
You're very welcome!
