[Bug/Regression] UI does not allow for wildcard website url
mnoser
New User
Both in the admin console and the webclient admin does the validation not allow the * character to be in the website url field.
A search on this topic in the forums revealed that wildcard support was added, so this should be possible.
This should be fine.
Which version of the 3cx system are you using?
18.0 Update 5 (Build 418). Should be the newest version.
Give a try with the full name of the site without the wildcard. Does this work?
Yes that works.
It seams to be a Firefox only issue. I just tried it in Chrome and there wildcard works.
I am glad that this is now working for you.
AshokUmmiti
