buying from partner or online should be the same price?
ITSmartwork
the question is: buying from partner or online should be the same price?
License only and nothing else, no support
thank you
Correct, buy through a partner then you have a relationship you can go to if you need help.
Reactions: jed
So basically the partner get the margin prpfit from 3cx, right?
Depends on the partners business model. They may mark up depending on the service offered.
Reactions: jed
The case is just license and nothing else...
Then id expect to pay RRP.
Reactions: jed
The case here is that is almost double the price on the 3cx website...
The partner added tha VAT and taxes....
Where are you? What are you looking to buy?
Reactions: jed
Because they don't have a choice as a business. Taxes are taxes. It shouldn't be a deal breaker as it's all deductible anyway.
Buying from a partner helps them too, and allows them to help you if needed. It's not always about the price.
Reactions: jed
Sure i understand but the taxes and vat are not 100%+ and we are talking about the license only. No other service is included.
At this point, next year is better to renew it online...
Have you even challenged your provider or are you just venting?
Reactions: jed and Evolute IT
Or find a different partner. Maybe that one is also marking up the license.
Depending on the size, feel free to reach out. We don't mark up licenses at all and we can avoid sales tax if you're not Canadian.
ARKC
