Solved C# code to check Extension
FG Admin
I was looking for ways to check if the user's input is a valid extension or not (if the extension exists or not) and if the extension was registered or not (is it logged in on any soft/desktop phone or Mobile App).
I found some code here on the forums to do that, But since I am not a developer myself, I was struggling trying to use this code.
For example, this method:
C#:
PhoneSystem.Root.GetDNByNumber()
I tried using it this way
C#:
public bool CheckValidExt(string UserInput)
    DN dn = PhoneSystem.Root.GetDNByNumber(UserInput);
    return (dn != null);
But received the following error
C#:
2024/03/27 15:59:27.643|12660|0006|Err|ScriptRunner.ScriptRunner-----
:[31013..31026)E: (610,27)-(610,40): Error CS0161: 'Main.CheckValidExtC682329230ECCComponent.CheckValidExt(string)': not all code paths return a value
            private object CheckValidExt(string UserInput)
:[31077..31083)E: (612,12)-(612,18): Error CS0106: The modifier 'public' is not valid for this item
:[31089..31102)W: (612,24)-(612,37): Warning CS8321: The local function 'CheckValidExt' is declared but never used
-------FAILED to compile---------
I was looking for pointers on how I would use this method (including Execute C# code component config ie: Method Name, Input parameters)
As well as this code to check the entered extension registration status:
C#:
return ((Extension)PhoneSystem.Root.GetDNByNumber(extensionNumber)).IsRegistered;
Thanks in advance.
Remove the method signature, leave only the method body in the Execute C# Code. It already wraps it in a method.
Thanks, it seems to be compiling alright now. I will make some audio prompts and a condition to parse the return value, whether true or false (easier to debug that way instead of reading the log:D).
Thank you so much, both methods worked exactly as needed.
You can mark this thread as solved.
Another thing: very special thanks to both @ConceptsWeb and @edossantos You have helped me way more than you know, I have been reading your answers to other forum users' questions for two weeks now (ranging from 2017 to 2023 !) and I managed to create my current call flow (way more complex to my liking and in a sense replicates the already built in IVR functionality @ConceptsWeb I read that reply by the way and felt personally attacked xD but to be fair to myself I haven't come up with a better way around the V18 Queues working hours limitations nor have I found this thread when I first set on to make my call flow) but now that it's done I might as well use it :). Anyway, I just wanted to say that this has been possible only thanks to you two ♥♥♥.
V20 will probably fix a lot of things for you. Call queues can follow department hours and have different behaviors based on that.
Bluebox Global
