Calculate call direction using CDR data
g.matheou
Forum User
I would like to calculate the call direction (local, inbound, outbound) of each call using the exported CDR data. I am thinking to use the from-type and to-type fields for doing this. Is there any documentation that explains the different values that can be set in these two fields?
Kind Regards,
George
There's also the FinalType to consider (as well as From & ToType). I've never seen any documentation detailing all possible fields and their usage, however if you look at this thread (In French) you will see at the bottom that @Cashmag_France has listed all the possible call types. This matches what I use in CallSequitur (which you might want to take a look at if you want a ready made CDR solution)
Thank you very much @Cjay !
arneg
