Call Control API for Windows - Force PBX Hours dont' work
gianluca67
Yes, that file location has been changed recently (3CX v20 U2), and the documentation was not updated. But a minor change should make it work.
Hi but I guess the change should be done by 3cx right? Many Thanks
The change in the documentation, yes. But you can change your code to point to the new file location.
Sorry,
How can I change the path?
Many Thanks
Search in the C# code for "3CXPhoneSystem.ini", and change the path to the correct location.
Reactions: NatalyS_3CX
ARKC
