Call Control API: How to check call status/ID for escalation logic (with a 30-minute delay)?
Sonal-MA
Platinum Partner
Hi everyone,
I am working on a project involving the Call Control API. The workflow is as follows:
  1. A user creates a ticket in a ticketing system.
  2. The system triggers an HTTP request to the callcontrol/makecall endpoint to call the engineer on duty.
  3. The Challenge: If the first engineer does not answer, the system needs to escalate and call the next engineer—but only after a 30-minute delay.
What currently works:The ticketing system successfully initiates the call to the first engineer via the REST API.
Where I am stuck:I need a reliable way to check the call logs to determine whether the call was answered or missed. I tried using the Configuration API (ReportCallLogData / Pbx.GetCallLogData), but I cannot find a unique callId to filter or search the logs for that specific call.
My questions:
  • Is there a way to retrieve a unique identifier (callId) when initiating a call via callcontrol/makecall so I can query its status later?
  • Should I stick to the REST API for this verification, or is it better to switch to a WebSocket connection to listen for real-time call events (like no-answer/busy)?
Any insights or best practices on how to handle this escalation logic would be greatly appreciated!
Many thanks!
We built this using CFDs. Much easier and simpler, with a backend DB.
@VoIPTools also has a great tool built for this.
I wouldn't bother reinventing the wheel.
For this workflow I would not rely on the call log or ReportCallLogData.
The makecall response may sometimes include a participant/result with callid, but it is not guaranteed in every makecall mode. For real-time escalation, the better approach is to use Web Call Control WebSocket events.
Recommended flow:
1. Connect to /callcontrol/ws.
2. Send POST /callcontrol/{dnnumber}/makecall.
3. Listen for participant events.
4. When an event references an entity like:
/callcontrol/{dnnumber}/participants/{id}
call:
GET /callcontrol/{dnnumber}/participants/{id}
5. The participant snapshot includes fields such as status, callid, legid, dn and party_dn.
6. Use status to decide the result:
- Connected = answered
- participant removed before Connected = missed/no-answer/failed
- Busy/Failed/Disconnected/Cancelled = failed
So yes, you can get a callid, but the reliable place to get it is from the live participant state, not from querying historical call logs after makecall. For escalation logic, WebSocket + participant snapshot is the recommended design.
Recommended flow:
call:
Thank you so much! This is incredibly helpful and exactly the technical guidance I was looking for.
Your recommended workflow using the WebSocket connection (/callcontrol/ws) and checking the participant snapshots makes perfect sense.
I am going to implement this WebSocket approach right away. Thanks again for pointing me in the right direction!
Reactions: KyriacosS_3CX
amazingbv
