Call Control API V20 Update 4
peter_huang
Platinum Partner
We would like to build a sip softphone inthe crm and applied for the Websocket API.
It seem that the token can triggered only from backend.
If we would like to triggered from the Frontend it happens to CORS limit.
Will there be any update with the Websocket API service?
We create our own CRM system for client to build the outbound and inbound service integrated with 3CX.
The API documentation is all you got. You need to figure out the rest. 3CX will not provide development assistance for external things like that.
They provided the API, now you gotta figure out how it works based on the docs. There's also a few code examples they provided.
The cors is the limit of the frontend. If there would be a new way for the frontend to integrate it will be more useful for the call center integration.
There's no CORS for APIs.
EMMEPICASA
