Solved Call drops after 3 hours
SS001
Hi All,
I am testing a long duration call (24hour) and I can see that the 3CX PBX is dropping the call after 3 hours
I found this link referencing the problem: https://www.3cx.com/blog/docs/calls-end-after-3-hours/
I need some help with finding where to set the ' MAXCALLDURATION ' values. on the PBX. I can't find the field for Custom parameters.
I have signed up for the 1-year free cloud setup, where 3Cx spins up a free environment for me.
Any pointer on where I can set this value?
Go to Settings > Parameters and on page 13 you will see MAXCALLDURATION
Reactions: nub
You can't adjust parameters with 3CX hosted instances. If you need to make this change, you'll have to self-host.
Thanks, Cobaltit and Jpatel for the replies. Looks like I am not able to change it. Do you you think if I pay for the professional licence then I can request 3CX to change these settings on my hosted instance?
I don't think it may change something, as Cobaltit said best is to host by yourself and even with free licence you'll be able to access full settings in 3cx console.
Now , max call duration can be a settings on trunk provider side too.
It's not a license limitation, it's a 3CX hosting limitation. No matter what license type you have, you will not have access to those parameters. 3CX keeps the hosting environment very tightly controlled to minimize support costs.
@SS001 Can you PM me with your license key please ?
ICTSupport@bedfordgirlssc
