Call Duration
Erick Moraes
Hi everyone,
I have question.
In my 3CX, the call have duration the 15 min. After, the call is over. How i can change this?
P.S. In parameters, value is 10800 in MAXCALLDURATION. And SIPPINGPERIOD is 100 and MAXNOANSWERTIMEOUT is 400.
Please, i need help!!
Please provide these:
  • 3CX Version, e.g. Standard Annual 16.0.2.910
  • Server OS, e.g. Debian 9 / Windows Server 2012 R2 / Raspberry Pi
  • Is the 3CX Server Hosted and where?
  • IP Phone Make/Model/Firmware
  • Provisioning Method: Local / VPN / STUN / SBC
  • Trunk Provider or Gateway Make/Model
  • Has the Firewall Checker passed: YES / NO
  • Are custom Phone Templates being used: YES / NO
Hi Frederick, thanks for feedback.
  • 3CX Version, = 16.0.6.655
  • Server OS, = Debian 9
  • Is the 3CX Server Hosted and where? = Google Cloud
  • IP Phone Make/Model/Firmware = I use APP
  • Provisioning Method: Local / VPN / STUN / SBC = I use APP
  • Trunk Provider or Gateway Make/Model = Advance(BR)
Is this happening on all calls or just external or just internal?
Just external.
Most likely, the issue is with your Provider and specifically with the "Session Timer".
I am just guessing here, but if you make a wireshark capture, and check the SIP messages of a call, in the INVITE and/or 200 OK you will most likely see something like this:
This states that before the interval set, one of the 2 parties must send a "refresh" message, which is either an INVITE or UPDATE, stating that they are still alive. Who must send this depends on the "refresher" value.
What I suspect, one of the 2 ends, usually the provider, is not sending the SIP message before the interval and the PBX is dropping the call.
hughesdouglas
