Call Flow Designer to 3cx call Que.
Nickz
Hi Could someone explain an issue I am having.
I have setup my call flows in the designer press 1 press 2 etc and the build is to an extension number 8010 which the zip has imported to 3cx with no issues.
When I dial in the office the extension number 8010 of the call flow I get press 1 press 2 works fine.
But I want to use call que in 3cx as I cannot find it in the Call flow designer app which I have set up as extension 8012.
By calling 8012 that works fine but how do I direct option press 1 to the call que of 8012.
Thanks.
You need to use the Transfer component for that.
Reactions: edossantos
Hassan Murasan
