Solved Call Flow Designer - Webhook
Dan - EAC
Hi.
I've been looking at Webhook options for 3CX for one of our customers. Looking around people seem to mention installing something on the 3CX machine and using a 3rd party service like creomate.. so I thought how hard can it be.
The idea is:
Caller calls in and hits the IVR
One of the prompts will be dedicated to the webhook.. lets say 8.
When caller presses 8 - they will be greeted with a prompt to say their call will be handled over whatsApp
The number will be recorded and forwarded onto a 3rd party tool.. AI flow handler - After this point its not my problem!
Anywho, I believe I've done the hard part and designed this in CFD.. which testing with a test webhook site seems to work
The script in question performs by..
* Playing the custom prompt
* Captures the caller's number
* Sends that information via a HTTP POST to the destination URL
* Ends call
My only silly question is.. how do I prepend a static 0 or +44 before the number being captured as the numbers show like the screenshot above.
Solution
Aha this is what I was trying but not to worry I've found my error...o_O
So.. ahem.
When using the site webhook.site to test this works. The output format has JSON ticked.
Unticking this showed my missing digit!
Appreciate the response.
Hello Dan - EAC,
I would guess that you can add this in the HTTP POST message:
Just concatenate the +44 before the number, when sending the information.
Paulo
So.. ahem.
Solution
KylieWilderman
