Call Forwarding to external number
Scott EIT
We divert our unanswered calls to Number A - which is working correctly, but the Caller Line Identity (incoming number) is not showing, it just forwards Number B - which is our own number
We need 3CX to forward the incoming number with the divert, not our own one
Is this something that is possible?
Depends on your sip trunk provider... CLNS?
While this does require that your provider allows any number to be sent (as mentioned), it will also depend on some other factors, including the type of forwarding used, and some trunk settings.
tom.walker@blackcountryra
