Call forwarding
Christian klarer
Hi All
I got a strange behaviour that I can't get my head around.
All calls to Extension 211 are forwarded to a external number . Even calls to a ring group with the specified user in it.
Remove the user from ring group → resolved
Delete user → resolved
Make a new user with same internal number 211 → Calls will be forwarded again
Updated to 18.0 Build 415 → not resolved
PBX is on premise.
Thanks for the help
Do you have IP phone connected to this extension?
Yes I have(had) because i deleted the extension. My next move would be reset the phone and then make the extension again with the same extension number.
That's what I advise you to do.
There may be a call forwarding set on the deskphone directly and those can cause issues since 3CX doesn't support that. Only the statuses forwarding is supported.
That was my thought to, and so it was. After reset, the phone worked again
mazet
