Call history - automatic purge of calls older than...
Dietmar
is there a way to meet GDPR-needs with the call-history (For instance: to delete all calls older than 3 months)?
It would be even better to have autopurge-settings for different lines (for instance: Hotline 3 months, regular line 1 month)
Thanks in advance!
Dietmar
Hello @Dietmar
3CX Version 18, Update 5 includes an improved call history purge function. From the dashboard, you can click on the call history purge button here:
You will then be presented with the following options:
Currently, the only auto-purge option is available for chat messages.
Dear @Keith Winhall_3CX,
thanks for your info - that are great news! We are running 18.0.4.965 till tomorrow (update-window). So we will have this opportunity also. Great.
Hope 3CX will feature an update with automatic purge for calls older than x months. Would be great.
TA!
Dietmar
Reactions: Keith Winhall_3CX
it worked flawlessly.
The automatic update did it's job with the one update - but after this servicereboot it seems to wait for the next updatewindow even with a new update waiting to install (which then had afterwards another update waiting). So the automatic-updater works only for 1 update :(
TA!
Dietmar
VR46
