Hi.Perhaps you can start searching info in "activity log" from dashboard and see if caller number appears or if anonymous is present .
just do an incoming call to your pbx from mobile for example and follow what happens in log
I call ISP and they told me that service ID is aviable on this line. We must check Patton or 3cx.Hello @ Gnomx
There are several parameters to consider that affect the inbound caller ID. The first thing you need to check is if your provider is sending you a caller ID in the Invite.
Then you need to find out in what SIP field the caller ID is available. Once you know that, you need to adjust your Inbound parameters to read the callers name and number from the correct SIP fields.
# SN4114/JO/EUI #
# R6.9 2017-03-13 H323 SIP FXS FXO #
# 1970-01-03T06:08:17 #
# SN/00A0BA0DC9BF #
# Generated configuration file #
cli version 3.20
clock local default-offset +00:00
webserver port 80 language en
system
ic voice 0
low-bitrate-codec g729
profile ppp default
profile call-progress-tone defaultDialtone
play 1 200 425 0
pause 2 200
play 3 600 425 0
pause 4 1000
profile call-progress-tone defaultBusytone
play 1 200 425 -7
pause 2 200
profile tone-set default
profile voip default
codec 1 g711ulaw64k rx-length 20 tx-length 20 silence-suppression
codec 2 g711alaw64k rx-length 20 tx-length 20 silence-suppression
codec 3 g729 rx-length 20 tx-length 20 silence-suppression
fax transmission 1 relay t38-udp
profile pstn default
echo-canceler-hybrid-loss 0
echo-canceler-nlp silence
profile sip default
no autonomous-transitioning
profile aaa default
method 1 local
method 2 none
context ip router
interface IF_IP_WAN
ipaddress dhcp
tcp adjust-mss rx mtu
tcp adjust-mss tx mtu
interface IF_IP_LAN
ipaddress 192.168.1.4 255.255.255.0
context cs switch
routing-table called-e164 RT_SIP_TO_FXO
route .% dest-service HG_TO_FXO
routing-table called-e164 RT_FXO_00_TO_SIP
route default dest-interface IF_SIP MT_CALL_ID_00
routing-table called-e164 RT_FXO_01_TO_SIP
route default dest-interface IF_SIP MT_CALL_ID_01
routing-table called-e164 RT_FXO_02_TO_SIP
route default dest-interface IF_SIP MT_CALL_ID_02
routing-table called-e164 RT_FXO_03_TO_SIP
route default dest-interface IF_SIP MT_CALL_ID_03
mapping-table called-e164 to called-e164 MT_CALL_ID_00
map .% to 000000
mapping-table called-e164 to called-e164 MT_CALL_ID_01
map .% to 000001
mapping-table called-e164 to called-e164 MT_CALL_ID_02
map .% to 000002
mapping-table called-e164 to called-e164 MT_CALL_ID_03
map .% to 000003
interface sip IF_SIP
bind context sip-gateway GW_SIP
route call dest-table RT_SIP_TO_FXO
remote 192.168.1.190 5060
early-disconnect
address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
trust remote
interface fxo IF_FXO_0
route call dest-table RT_FXO_00_TO_SIP
loop-break-duration min 60 max 1000
disconnect-signal loop-break
disconnect-signal busy-tone
ring-number on-caller-id
dial-after timeout 1
mute-dialing
interface fxo IF_FXO_1
route call dest-table RT_FXO_01_TO_SIP
mute-dialing
interface fxo IF_FXO_2
route call dest-table RT_FXO_02_TO_SIP
mute-dialing
interface fxo IF_FXO_3
route call dest-table RT_FXO_03_TO_SIP
mute-dialing
service hunt-group HG_TO_FXO
drop-cause destination-out-of-order
drop-cause user-busy
drop-cause normal-unspecified
drop-cause no-circuit-channel-available
drop-cause network-out-of-order
drop-cause temporary-failure
drop-cause switching-equipment-congestion
drop-cause access-info-discarded
drop-cause circuit-channel-not-available
drop-cause resources-unavailable
route call 1 dest-interface IF_FXO_0
route call 2 dest-interface IF_FXO_1
context cs switch
no shutdown
authentication-service AS_ALL_LINES
realm 1 3CXPhoneSystem
username 10000 password 8g/s9s6iL+74Pu5YxZuvBQ== encrypted
location-service LS_10000
domain 1 192.168.1.190
identity-group default
authentication outbound
authenticate 1 authentication-service AS_ALL_LINES username 10000
identity 10000
registration outbound
registrar 192.168.1.190 5060
lifetime 300
register auto
interface LAN
bind interface IF_IP_LAN context router port 5060
bind location-service LS_10000
no shutdown
port ethernet 0 0
medium auto
encapsulation ip
bind interface IF_IP_LAN router
no shutdown
port fxo 0 0
encapsulation cc-fxo
bind interface IF_FXO_0 switch
no shutdown
port fxo 0 1
bind interface IF_FXO_1 switch
no shutdown
port fxo 0 2
bind interface IF_FXO_2 switch
shutdown
port fxo 0 3
bind interface IF_FXO_3 switch
shutdown
So What do I have to do?? I'm a bit confused...If that is your trunk (FXO) gateway, using a PSTN connection, the parameters you listed don't show what type of Caller ID has been configured. The type used in the gateway must match that used by your provider.
Ok brother. I need you help on this... Please tell me the CLI command in order to retrive info.Agree with the above, confirm with the provider first or everything else in this ticket string is a waste of time.
Some providers will charge extra for CLID on the line.
If they can't help I can send you some commands for the CLI of the Patton which could potentially provide the information you need.
How can I open terminal in order to using theese command line?Commands for the FXO device should be:
enable
debug call-router
debug call-control
debug fxo
debug ccfxo
debug context sip-gateway signaling detail 5
debug context sip-gateway transport detail 5
debug context sip-gateway error
Run these, replicate the issue and send over to me as an attached notepad file (not in the body of the string) I will then take a look, also the CLI that it should be.
You can stop the output of the above with the command "no debug all".
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
