Call Journal no matchings found
alex9201
SMB User
XML:
<?xml version="1.0" encoding="utf-8"?>
<Crm xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Country="CZ" Name="AutoCRMv2" Version="1" SupportsEmojis="true" SupportsTranscription="true" ListPageSize="0">
  <Number Prefix="AsIs" MaxLength="9" />
  <Connection MaxConcurrentRequests="20" />
  <Parameters>
    <Parameter Name="UserName" Type="String" Parent="General Configuration" Editor="String" Title="Username:" Validation="" Default="" ListValues="" RequestUrl="" RequestUrlParameters="" ResponseScenario="" />
    <Parameter Name="Password" Type="Password" Parent="General Configuration" Editor="String" Title="Password:" Validation="" Default="" ListValues="" RequestUrl="" RequestUrlParameters="" ResponseScenario="" />
    <Parameter Name="ReportCallEnabled" Type="Boolean" Parent="" Editor="String" Title="Enable Call Journaling" Validation="" Default="false" ListValues="" RequestUrl="" RequestUrlParameters="" ResponseScenario="" />
    <Parameter Name="Subject" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Call Subject:" Validation="" Default="3CX PhoneSystem Call" ListValues="" RequestUrl="" RequestUrlParameters="" ResponseScenario="" />
    <Parameter Name="InboundCallText" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Answered Inbound Call:" Validation="" Default="[DateTime]: Answered incoming call from [Number] to [Agent] ([Duration])" ListValues="" RequestUrl="" RequestUrlParameters="" ResponseScenario="" />
    <Parameter Name="MissedCallText" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Missed Call:" Validation="" Default="[DateTime]: Missed call from [Number] to [Agent]" ListValues="" RequestUrl="" RequestUrlParameters="" ResponseScenario="" />
    <Parameter Name="OutboundCallText" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Answered Outbound Call:" Validation="" Default="[DateTime]: Answered outgoing call from [Agent] to [Number] ([Duration])" ListValues="" RequestUrl="" RequestUrlParameters="" ResponseScenario="" />
    <Parameter Name="NotAnsweredOutboundCallText" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Unanswered Outbound Call:" Validation="" Default="[DateTime]: Unanswered outgoing call from [Agent] to [Number]" ListValues="" RequestUrl="" RequestUrlParameters="" ResponseScenario="" />
    <Parameter Name="Transcription" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Transcription" Validation="" Default="" ListValues="" RequestUrl="" RequestUrlParameters="" ResponseScenario="" />
    <Parameter Name="RecordingUrl" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Recording URL" Validation="" Default="" ListValues="" RequestUrl="" RequestUrlParameters="" ResponseScenario="" />
    <Parameter Name="Summary" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Summary" Validation="" Default="" ListValues="" RequestUrl="" RequestUrlParameters="" ResponseScenario="" />
  </Parameters>
  <Authentication Type="Basic">
    <Value>[UserName]:[Password]</Value>
  </Authentication>
  <Scenarios>
    <Scenario Id="" Type="REST" EntityId="" EntityOrder="">
      <Request SkipIf="" Url="https://instance.espocrm.com/api/v1/lookupContact?phoneNumber=[Number]" MessagePasses="0" Message="" RequestContentType="" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
      <Rules>
        <Rule Type="Any" Ethalon="">id</Rule>
      </Rules>
      <Variables>
        <Variable Name="ContactID" LookupValue="" Path="id"><Filter /></Variable>
        <Variable Name="FirstName" LookupValue="" Path="firstName"><Filter /></Variable>
        <Variable Name="LastName" LookupValue="" Path="lastName"><Filter /></Variable>
        <Variable Name="CompanyName" LookupValue="" Path="accountName"><Filter /></Variable>
        <Variable Name="Email" LookupValue="" Path="emailAddress"><Filter /></Variable>
        <Variable Name="PhoneBusiness" LookupValue="" Path="phoneNumber"><Filter /></Variable>
        <Variable Name="CustomValue" LookupValue="" Path="entityType"><Filter /></Variable>
      </Variables>
      <Outputs AllowEmpty="true">
        <Output Type="ContactID" Passes="0" Value="[ContactID]" />
        <Output Type="FirstName" Passes="0" Value="[FirstName]" />
        <Output Type="LastName" Passes="0" Value="[LastName]" />
        <Output Type="CompanyName" Passes="0" Value="[CompanyName]" />
        <Output Type="Email" Passes="0" Value="[Email]" />
        <Output Type="PhoneBusiness" Passes="0" Value="[PhoneBusiness]" />
        <Output Type="CustomValue" Passes="0" Value="[CustomValue]" />
        <Output Type="ContactUrl" Passes="0" Value="https://instance.espocrm.com/#[CustomValue]/view/[ContactID]" />
        <Output Type="EntityId" Passes="0" Value="[ContactID]" />
        <Output Type="EntityType" Passes="0" Value="Contacts" />
      </Outputs>
    </Scenario>
    <Scenario Id="LookupByEmail" Type="REST" EntityId="" EntityOrder="">
      <Request SkipIf="" Url="https://instance.espocrm.com/api/v1/lookupContact?emailAddress=[Email]" MessagePasses="0" Message="" RequestContentType="" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
      <Rules>
      </Rules>
      <Variables>
      </Variables>
      </Outputs>
    </Scenario>
    <Scenario Id="ReportCall" Type="REST" MessagePasses="0" EntityId="" EntityOrder="">
      <Request SkipIf="" Url="https://instance.espocrm.com/api/v1/createCall" RequestContentType="application/json" RequestEncoding="Json" RequestType="Post" ResponseType="Json">
        <PostValues>
          <Value Key="name" Type="String">[Subject]</Value>
          <Value Key="status" Type="String">
            [CallType]==Unknown?
                ([CallDirection]==Inbound?Missed:Notanswered)
                :[CallType]
          </Value>
          <Value Key="dateStart" Type="String">
            [CallEstablishedTimeLocal]==NULL?[[CallStartTimeLocal].ToString("yyyy-MM-dd HH:mm:ss")]:[[CallEstablishedTimeLocal].ToString("yyyy-MM-dd HH:mm:ss")]
          </Value>
          <Value Key="dateEnd" Type="String">
            [CallEndTimeLocal]==NULL?[[CallStartTimeLocal].ToString("yyyy-MM-dd HH:mm:ss")]:[[CallEndTimeLocal].ToString("yyyy-MM-dd HH:mm:ss")]
          </Value>
          <Value Key="duration" Type="Integer">
            [DurationTimespan]==NULL?0:[[DurationTimespan].get_TotalSeconds()]
          </Value>
          <Value Key="direction" Type="String">[CallDirection]</Value>
          <Value Key="phoneNumber" Type="String">[Number]</Value>
          <Value Key="extension" Type="String">[Agent]</Value>
          <Value Key="description" Type="String">Call from 3CX</Value>
          <Value Key="entityId" Type="String">[EntityId]</Value>
          <Value Key="entityType" Type="String">[EntityType]</Value>
          <Value Key="transcription" Type="String">[Transcription]</Value>
          <Value Key="recordingUrl" Type="String">[RecordingUrl]</Value>
          <Value Key="summary" Type="String">[Summary]</Value>
        </PostValues>
      </Request>
      <Outputs AllowEmpty="true" />
    </Scenario>
  </Scenarios>
</Crm>
Can someone explain why the Call Journal part fails like so:
[Integration.Crm.CallProcessingService] CRM: Triggering Call Journaling with values - CallType='Inbound' - PhoneNumber='<number>' - ContactName='<contactName>' - AgentExtension='096' - AgentFirstName='<firstName>' - AgentLastName='<lastName>' - AgentEmail='<email>' - ContactRawData='65ac8798bb3a2f51b|Contact' - StartTime='07/08/2025 14:06:26' - EndTime='07/08/2025 14:06:40' - EstablishedTime='07/08/2025 14:06:26'
[Integration.Crm.Engine.ResultVariableScenarioProcessor] CRM: Processing scenario 'ReportCall'.
[Integration.Crm.Engine.BasicAuthHttpClientProvider] CRM: Creating new HttpClient for Basic authentication
[Integration.Crm.Engine.ResultVariableScenarioProcessor] CRM: Skipping request...
[Integration.Crm.Engine.ResultVariableScenarioProcessor] CRM: No matchings found.
FYI, I made this account just to post to the forum, the company I'm implementing this for uses enterprise edition
That's weird, the SkipIf attribute in the request is empty, so it shouldn't be skipped. Are you sure this is the XML template being used by 3CX? Maybe you uploaded a different version?
lonedigger
