Call per SIP trunk reports
PaoloConcari
Good morning, I have a PBX were I'm going to set many different SIP trunks
The customer asked for some reports but I noticed that in the Call Report I can't see a "via SIP" column to know which SIP trunk was used to make/receive the call
I need to create monthly reports for each trunk, is there any way to do this?
Thanks in advance
Paolo
We were keen to know if we're utilizing the SIP trunk as well.. we used to rely on a graph from the trunk supplier themselves to determine if we should increase capacity.
Turns out you can write a wee python script to convert a call report into a graph showing concurrent calls.
heapq & plotly are awesome.
We can build you any report you need.
Graham Robertson
