call pickup problem!
MuratDemirtas
Platinum Partner
Hello there;
After making call pickup the call remains open for many hours. I've sent a picture, how can I solve this problem?
Good work.
Normally, the callee shows the original recipient, and once you pickup the call, it shows the extension that picked the call.
The callee appears as *0, it seems like you have parked that call after you picked it up.
this call is turned on and off for 3 hours. Is there a way to shut it down?
You mean it's still running as we speak? Either pick it up from parking and end it or press the X in the Active calls menu of your management console to drop the call
florentrobineau
