Call quality report
PaoloConcari
Good evening everyone
I'm sorry if I missed something but I've checked the manual and the forum and I can't find anything
All the calls that I see in the Call Log have the options greyed out. In my case I need to check the quality report since some user reported me an issue with monodirectional audio
I'm the system owner of the PBX so I shouldn't have issues with the permissions. Any idea? I can monitor directly on the users but not on the call log.
Does it need the call recording enabled?
Enterprise 3CX self-hosted on GCP
Thanks in advance
Paolo
How long did they enable the call quality for? Are you looking in the call log report?
Thanks for the quick reply
That's what I was thinking, I can see there only if the user or me enables the monitoring?
Because in my case I should monitor "the trunk".
This specific issue happens in a flow that is: call sip trunk -> call script with CFD -> external transfer (mobile)
But I can't set the monitor on the CFD extension, so I suppose I'm stuck
not sure then if it doesnt show up after they've enabled it. you'd need to do some traces.
As I mentioned I can't enable on a user since it's a CFD script and then an external transfer. I would need something that monitors the CFD/the trunk itself
The Quality monitoring is only for the users. This call will have to go through a user on the system. You would need to do a capture on the PBX to see the call coming in to the PBX and then being forwarded straight out.
Reactions: PaoloConcari
How we do a capture on v20, please? Thanks
Hi, @kokolino23
I would recommend that you do the 3CX Advanced training and also attend the very regular 3CX Basic & Advanced training webinars.
See 3CX Webinars for dates.
Reactions: kokolino23
Graham Robertson
