- Joined
- Feb 3, 2023
- Messages
- 1
- Reaction score
- 0
I'm trying to implement the predictive dialer and I'm getting only a single number to the queue. When second number connecting the queue this error happens. Can you please provide me a solution for this issue?
Error log is this.
Error log is this.
| 02/09/2023 4:44:26 PM - Terminated from "MakeCall"<sip:[email protected]:5060>;tag=ffc8cc13 to <sip:[email protected]:5060;nofwd=1>;tag=c9853317; reason: Rejected |
| 02/09/2023 4:44:26 PM - L:89.1[Ivr:MakeCall] Sending: OnSendResp Send 480/INVITE from 0.0.0.0:0 tid=98900b33cd14f45f Call-ID=_7iGJ-WOIVrabOkAO-fE5A..: SIP/2.0 480 Temporarily Unavailable Via: SIP/2.0/UDP 127.0.0.1:5483;branch=z9hG4bK-524287-1---98900b33cd14f45f;rport=5483 To: <sip:[email protected]:5060;nofwd=1>;tag=c9853317 From: "MakeCall"<sip:[email protected]:5060>;tag=ffc8cc13 Call-ID: _7iGJ-WOIVrabOkAO-fE5A.. CSeq: 2 INVITE Warning: 499 debian "Not available" Content-Length: 0 |
| 02/09/2023 4:44:26 PM - SendMsg from <sip:[email protected]:5060;nofwd=1>;tag=c9853317 to "MakeCall"<sip:[email protected]:5060>;tag=ffc8cc13 |
| 02/09/2023 4:44:26 PM - Call(C:89) is terminated |
| 02/09/2023 4:44:26 PM - [CM503020]: Call(C:89): Normal call termination. Call originator: Ivr:MakeCall. Reason: Not available |
| 02/09/2023 4:44:26 PM - [CM503016]: Call(C:89): Attempt to reach <sip:[email protected]:5060> from Ivr:MakeCall has failed. Reason: Not Found |
| 02/09/2023 4:44:26 PM - Forwarding disabled by nofwd=1 param |
| 02/09/2023 4:44:26 PM - RerouteReq |
| 02/09/2023 4:44:26 PM - Leg L:89.2[Line:10000>>0XXXXXXXXX] is terminated: Cause: 404 Not Found/INVITE from 192.168.0.150:5060 |
| 02/09/2023 4:44:26 PM - L:89.2[Line:10000>>0XXXXXXXXX] got Terminated Recv 404/INVITE from 192.168.0.150:5060 tid=ec481666a13b9421 Call-ID=z20upABUBQv85G2Oi4PFzA..: SIP/2.0 404 Not Found Via: SIP/2.0/UDP 192.168.0.7:5060;branch=z9hG4bK-524287-1---ec481666a13b9421;rport=5060 To: <sip:[email protected]>;tag=16NDc39a9j3UF From: "8888" <sip:[email protected]>;tag=8b117234 Call-ID: z20upABUBQv85G2Oi4PFzA.. CSeq: 1 INVITE Accept: application/sdp Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, INFO, SUBSCRIBE, NOTIFY, REFER, UPDATE, REGISTER Supported: replaces User-Agent: DAG1000-8O DAG 2.81.10.12 Allow-Events: refer, ua-profile, message-summary, check-sync, dialog, presence Content-Length: 0 |
| 02/09/2023 4:44:26 PM - Terminated from <sip:[email protected]>;tag=16NDc39a9j3UF to "8888" <sip:[email protected]>;tag=8b117234; reason: Error |
| 02/09/2023 4:44:26 PM - Call to T:Line:10000>>0XXXXXXXXX@[Dev:sip:[email protected]] from L:89.1[Ivr:MakeCall] failed, cause: Cause: 404 Not Found/INVITE from 192.168.0.150:5060 |
| 02/09/2023 4:44:26 PM - L:89.2[Line:10000>>0XXXXXXXXX] got Failure: Failure Recv 404/INVITE from 192.168.0.150:5060 tid=ec481666a13b9421 Call-ID=z20upABUBQv85G2Oi4PFzA..: SIP/2.0 404 Not Found Via: SIP/2.0/UDP 192.168.0.7:5060;branch=z9hG4bK-524287-1---ec481666a13b9421;rport=5060 To: <sip:[email protected]>;tag=16NDc39a9j3UF From: "8888" <sip:[email protected]>;tag=8b117234 Call-ID: z20upABUBQv85G2Oi4PFzA.. CSeq: 1 INVITE Accept: application/sdp Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, INFO, SUBSCRIBE, NOTIFY, REFER, UPDATE, REGISTER Supported: replaces User-Agent: DAG1000-8O DAG 2.81.10.12 Allow-Events: refer, ua-profile, message-summary, check-sync, dialog, presence Content-Length: 0 |
| 02/09/2023 4:44:26 PM - [CM503003]: Call(C:89): Call to <sip:[email protected]:0> has failed; Cause: 404 Not Found/INVITE from 192.168.0.150:5060 |
| 02/09/2023 4:44:26 PM - Session 12699 has failed in leg L:89.2[Line:10000>>0XXXXXXXXX] ; Cause: 404 Not Found/INVITE from 192.168.0.150:5060 |
| 02/09/2023 4:44:26 PM - Failure from <sip:[email protected]>;tag=16NDc39a9j3UF to "8888" <sip:[email protected]>;tag=8b117234 |
| 02/09/2023 4:44:26 PM - [CM503025]: Call(C:89): Calling T:Line:10000>>0XXXXXXXXX@[Dev:sip:[email protected]] for L:89.1[Ivr:MakeCall] |
