Call queue logging?
SAM-dgap
Is there an actual log for call queue routing, or do I have to rely on a queue report?
Thanks!
Routing? What do you mean?
There are call reports.
There is a 3CXQueueManager.log in the instance folder but you may need to increase your logging to get more information.
Sorry that could have been a little more descriptive. I am trying to find out what happens when a call hits a queue - i.e., what decision it makes when it picks what phone to ring. I will check the log fine you suggested. Thank you!
You will find that in the log i mentioned.
Reactions: SAM-dgap
Thanks - I increased the logging level and will use that info when I have another incident that requires me to look at it. I appreciate your answer!
TVV40
