Solved call queue no audio
Aroma
Hello, recently I got a problem in the call queue where there is no audio when the call is picked up. I've tried to disable Support Re-Invites for the user extension, and the audio works. However, when the agent ends the call, it remains open on the other side. Additionally, when I try to enable Support Re-Invites, there is no audio, and the call ends after 30 seconds. Also, all buttons in the control are disabled. it was working and I didn't do any changes . V 18.0 (Build 20)
thanks
1715542565819-png.41394
Hi there.
Support Re-Invites and Support Replaces should always be ON, in the users/extension settings, BUT always OFF on the SIP trunk settings.
Do you have any issues when calling between 2 internal users?
No issue between 2 internal users and external call is working , I have restarted the server, but the issue remains the same. I tried to change the Inbound Rules for one of the users attached to that call queue and made it a direct extension. Now, I can hear the dialer."
Does your firewall checker pass?
This is something essential and needs to be done in the first place.
I don't put 3cx in public mode because it's behind a firewall , it's not a firewall issue It has been working since I configured it.
Again, as I told you, I have another Call queue and it's working without a problem
How are the calls then coming to the System, are you using FXO gateway?
I'm using SIP trunk form ISP
So you have a local hardware that communicate with the 3CX over local IP address?
The problem was solved by changing some configurations in the SIP trunk.
Perfect, and thank you for the feedback provided.
I will close this thread now.
Have a nice day
ARKC
