- Joined
- Jun 3, 2020
- Messages
- 28
- Reaction score
- 2
hi guys i've read a previous post about queue recording for all call (https://www.3cx.com/community/threads/queue-call-recording.75963/)
the answer is incorrect, because to register all incoming call in a queue it need to use the recording setting in the queue and not the recording setting in the extension, because using the recording setting in the extension, it will record all call also the call of users that choise to haven't recorded pressing DTMF 3, and this is a privacy violation.
the real problem is the malfunction of recording option in the queue, because if i configure to register only user that press DTMF 3, it work fine without configuring anything on the extensions, but if i configure register always except when pressed DTMF 3 this non work.
but the extension configuration replace all queue setting so is not the right way, the right way is that 3cx close the queue recording BUG.
somebody else noticed this bug?
regards
Emiliano
regards
Emiliano
