Call recording location
Alan.Burgess
Is adding a second disk and moving the location of the call recordings a supported solution if you have deployed 3CX to Azure using the Azure template, or is the better option simply to make the OS disk large enough to store required amount of recordings? (we are NOT looking to archive the call recordings at this time)!
Alan
Hi Alan,
I think the better option is simply to make the OS disk large enough to store the required amount of recordings.
Using archiving would probably be a better idea. You can still see and access those recordings even archived ones.
Reactions: Alan.Burgess
Hi Alan,
It would be a second "local" disk, but I know that ensuring the correct security has been applied in Linux can be an interesting challenge, so it might be simpler to extend the disk.
The only issue with archiving would that I would need to stand up a new server to archive it to. As it's call recordings regarding sensitive data it brings a whole world of other security around protecting the new machine. Extending the disk would be the simplest option at this stage ;)
Yeah, well 3CX also supports archiving to Google Buckets (which can be secured) so that could be an other route.
WinSip
