Solved Call Recordings silent
GedPerryman
We've recently upgraded to v20. I've just noticed that when you download a call recording the file appears to be the correct length for the length of the call, but it is completely silent. Any ideas?
Just noticed the "play" button in the call log and the call plays when I click that - it's just the downloaded wav file that is silent.
Hi there.
Is it for all the recordings, or some of them only?
This appears to be all of them since the upgrade - I've noticed older calls don't seem to have a download link (we archive to Google).
So if you place a new call and record it, while having the audio in the call, and you can confirm it, does it mean it is still silent?
We have all calls set to record automatically. I called the office on my mobile a few minutes ago and the call was fine. When I click the "play" button in the call log it plays the recording of the call perfectly. When I click the download link I get a wav file downloaded, but it is silent (the file plays for the same length as the call recording should be - just no sound!).
What do you use to play the file? Did you try VLC for example?
It works in VLC! Any ideas why it doesn't play anything in Windows Media Player?
Reactions: OlegR_3CX
Not sure what is installed on your OS, and the codes there in your Windows player. So the issue seems in your player.
Thanks I agree.
Perfect. I will close this thread now.
Have a nice day
amazingbv
