Solved Call Reports limited to 30 days?
Bigbossnass00
This is dumb and I'm sure it's easier than I'm making it. Under Admin Console --> Reports --> Call Log, it appears the default range is 30 days and I can't seem to find a way to change it. I need to go back 90 days (or preferably more).
I don't want to say "the previous version could do it" but......
Hi there.
You can change that and this option is fixed.
In case you need more information on the calls, run the report.
Hi there.
I guess I don't understand what "run the report" means. I thought I was doing that. Can the report be customized or a new call report with a longer time frame created?
So if you click on "seach" , you will be able to customize the range of the dates :
Ah, I see there a little "filter" icon in between "Call type" and "Search".
As I said, this was easier than I was making it!
Thanks for the help.
You are always welcome.
Have a nice day
PacketPilgrim
