Call Screening to an extension...
phild-cxcxcx
I have read many posts about this, and wondered if there was any progress towards
adding it to 3cx, or providing a workaround..
Here's the desired scenario:
A caller dials an extension ( wither directly or through an IVR).
The caller is prompted for their name.
The the call rings the extension, and when answered,
the name is played, and a prompt is played "accept the call, or
go to voicemail "
I know this is set up for mobiles, but not to an extension..
Is there any way to do in 3cx currently?
Thanks,
Phil
I also wanted to know what one of the forwarding options means:
"transfer to number"?
This is the same drop-down as "transfer to mobile"...
Does it refer to sending the call to an outside number?
go to voicemail "
Thanks,
Phil
Check out the extension's options, there's "Screen calls using IVR". That's what it is.
Transfer to mobile uses the user's mobile phone field. Transfer to number will allow a custom number to be entered.
VR46
